crankshaft pulley
Old Jul 28, 2010 | 07:53 PM
my3000gt's Avatar
Default crankshaft pulley
Looking for information on removing the crank shaft pulley. Any help will be appreciated
Old Sep 19, 2011 | 03:37 PM
Cbean2009's Avatar
I can't get my crank shaft pulley off either. It doesn't have any holes in it like my manual says. Trying to find a impact wrench..but no luck.
Old Sep 19, 2011 | 10:43 PM
toddrs93's Avatar
a good sturdy air impact gun is what you usually have to use. There is a tool mitsu sells to hold the pulley but an air gun will do it, without that there are several tricks, such as "bumping it". Which involves disabling the car so it won't actually start, putting a ratchet and socket on the pulley bolt, and cranking the car over, using the force of the starter to break the bolt loose. Or pulling the starter and wedging the flywheel teeth and then breaking the bolt loose with a good breaker bar. the bolt is a 22mm or 7/8.
jx_mirage01
Jun 14, 2008 09:02 AM
Angelonia
Nov 15, 2006 04:05 AM
jacek
Dec 25, 2004 01:26 AM
LIQUIDSMILE
Jun 16, 2004 04:36 PM
03eclipseGT
Oct 6, 2003 08:43 PM
