Dead Battery
Old Oct 13, 2013 | 09:24 AM
beachy's Avatar
Default Dead Battery
I have a 1997 GT3000 that I installed an after market radio in. Worked great for several months and than it would not shut off when ignition was turned off. I would manually turn the radio off but the battery will die after two days of no use. If I use everyday no problem the drain is not enough to kill the battery. I don't know if the radio is the cause of the dead battery or that is a symptom of something else that is wrong. No other interior lights or electronics seem to be on??
Old Oct 13, 2013 | 12:25 PM
Akzle's Avatar
you wired it wrong? Or the ign sensing circuit has gone gay.
Reset everything!
Old Oct 14, 2013 | 09:47 AM
beachy's Avatar
I removed the after markert radio and put the stock radio back in. Going to see if i still have he problem.
KF97diamonte
May 5, 2010 01:38 PM
stbentoak
4th Generation
Apr 12, 2008 07:25 PM
wfewife
Jan 28, 2008 06:33 PM
wfewife
nyc95gst
Nov 16, 2007 04:30 PM
