how to change belts
Old Jul 8, 2007 | 06:29 PM
underpressure2003's Avatar
Default how to change belts
im changing the belts on my 94 dohc i have a base easier to change but the dohc is way diff im changing the 2 belts on it not the timing belt were is the ajuster to help me change them
Old Jul 9, 2007 | 10:50 AM
thestealth's Avatar
Default RE: how to change belts
Jack up the driver side, support the car with a jack stand is the easiest way to get to the tensioners. About the only "special" tool you need is a long 3/8" extension, this will allow you to adjust the power steering tensioner. The air/alternater tension is adjusted with a 10 or 12mm socket using the adjustment bolt on tensioner. I could have the tensioners backwards, but once you crawl under there, you should be able to figure it out easy enough.
DarkPoet
Mar 4, 2012 01:13 PM
blubyu88
Dec 12, 2006 08:26 PM
letsstophere
Feb 12, 2006 11:47 PM
g9s5t
Aug 21, 2005 07:04 PM
mesaboogie18
Oct 8, 2004 09:51 PM
