idle problems
Old Jun 8, 2004 | 08:32 PM
sunditty's Avatar
Default idle problems
hello
can any tell me what's wrong with my car. i have a 3000gt. evert time i stop the rpm bounce back and fourth 1500 to 2000rpm. i had it check out, had the throttle clean out but still continue to do it . it some time shut off when i stop.
Old Jun 8, 2004 | 09:10 PM
thestealth's Avatar
Default RE: idle problems
I have heard that a loopy idle can be caused by the IAC, idle air controller. It is located on the throttle body. I did a quick search on 3si.org and found lots of problems that may be similar to yours
http://www.3si.org/forum/search.php?...=356417&page=2
There is lots of topics (7 pages) but surely you will be able to figure out if one their problems matches yours.
If you find out it is the problem and you have to replace it......
http://www.stealth316.com/2-isc-iac.htm
here is some instructions. Good luck, let us know if that was the problem or not.
jp2000
Jan 1, 2012 05:21 PM
corey17
Feb 3, 2007 02:55 PM
reggieccrgto
Nov 7, 2006 07:47 PM
yamahablaster8230
Aug 29, 2006 09:28 AM
VR4Restored
Aug 14, 2004 03:57 PM
