Newbie needing some tech info
Thanks for the reply.
From what I can see from most online application charts, they use the F4A33-1 and 91 thru 99 3000gt, 3.0L will all interchange, and I guess that would hold true for stealths as well. Can anyone confirm this with certainity.
Thx,
Thx,
the basic AT should be the same but brackets and peripherals may be different depending on model and year. There will be more chance of differences if it's a Japanese crate motor trans also.
I did a engine swap on a 98 2WD and had to change the oil pan because the Japanese crate motor was AWD and wouldn't bolt to the existing trans because the pan had different brackets.
the first thing to check is electrical connectors, if they're not the same and you can't just change a sensor you're SOL.
Rob1120
06-16-2014 09:13 PM
TheEngineer
11-14-2007 06:45 AM
3000gt, 3000gtls, austin, differences, f4a33, f4a331, info, interchange, mitsubishi, rims, sl, sport, tcm, tech, tx
