Newbie needing some tech info
Old Mar 8, 2009 | 09:24 PM
buck6680's Avatar
Default Newbie needing some tech info
Hi all,
Just bought a 98 sl with a bad automatic tranny. Would someone tell me what years/models would interchange to do a swap.
Any help would be appreciated.
Thanks,
Old Mar 8, 2009 | 11:15 PM
3000gtls's Avatar
are you wanting to stay auto or are you wanting to swap to 5 speed man ???
Old Mar 9, 2009 | 06:53 AM
buck6680's Avatar
At this point, I prefer to keep it as simple as possible, so it would probably be best to stay with the automatic.
Thanks for the reply.
Old Mar 9, 2009 | 09:23 PM
buck6680's Avatar
From what I can see from most online application charts, they use the F4A33-1 and 91 thru 99 3000gt, 3.0L will all interchange, and I guess that would hold true for stealths as well. Can anyone confirm this with certainity.
Thx,
Old Mar 9, 2009 | 11:37 PM
NWM_Tech's Avatar
the basic AT should be the same but brackets and peripherals may be different depending on model and year. There will be more chance of differences if it's a Japanese crate motor trans also.
I did a engine swap on a 98 2WD and had to change the oil pan because the Japanese crate motor was AWD and wouldn't bolt to the existing trans because the pan had different brackets.
the first thing to check is electrical connectors, if they're not the same and you can't just change a sensor you're SOL.
Old Mar 10, 2009 | 02:58 PM
Manybrews's Avatar
not all are directly swappable. The solenoids did have different resistance values from early to later years, and plugging in the older ones will damage the TCM.
just get the correct year.
Old Mar 10, 2009 | 05:35 PM
Girly VR4's Avatar
Where are you located? We have one from a 98 SL for sale if you are interested.
Old Mar 11, 2009 | 04:44 AM
buck6680's Avatar
Southern Indiana, near Louisville, Ky. Pm me with your location and details.
Thx,
Old Mar 11, 2009 | 01:14 PM
Girly VR4 knows her stuff. You're safe doing business with her.
Old Mar 12, 2009 | 06:03 AM
buck6680's Avatar
Well, haven't heard from Girly, so I bought one out of Fla. that is out of a 95 stealth and is supposed to have been rebuilt less than a year ago. I hope this works.
Rob1120
Jun 16, 2014 09:13 PM
Alessandro57
Jan 20, 2011 09:43 AM
BrokeDad
May 31, 2009 05:30 PM
TheEngineer
Nov 14, 2007 06:45 AM
neeks
Dec 8, 2005 10:00 AM
