No 12V power / no start... then it's OK!!
Old Aug 10, 2013 | 02:26 PM
cdunlap's Avatar
Default No 12V power / no start... then it's OK!!
Help -
1999 3000gt sl
63k miles
manual
new battery
The car will randomly not have battery power. The headlight relay was clicking like mad sometimes. I replaced it thinking that was the cause of the battery drain. Wrong!
It's not a drain, it's more like a loose ground. The car will sometimes have no power to even move the seats. It will not start - no click of the solenoid - nothing. If you shake it around - maybe mess with the battery connections (which are tight) it will come back to life. WHAT!!
I've done complete teardowns/engine swaps/etc - but on BMWs. This is my wife's car and I can't find the (presumably) loose ground.
Where should I look? I have it up in the air and can't find anything obvious.
Help please!
Thanks
Chris
Old Aug 10, 2013 | 04:18 PM
cdunlap's Avatar
Default found loose +terminal
the + was as tight as it would get - but I was able to spin it a little bit by hand. There was alu.foil! under the clamp. I replaced the clamp = time will tell if that fixed it.
rexbd
Jan 29, 2008 07:18 PM
EclipseSlimRS
May 16, 2004 07:10 PM
Tom97rs
Nov 12, 2003 07:58 PM
