runs then dies then no spark
Old Jan 11, 2008 | 09:13 PM
Default RE: runs then dies then no spark
I am going to say CAS, ECU, or ignition control module
Old Jan 12, 2008 | 10:51 PM
cruisingthesouth's Avatar
If it is the ECU and it is number MD192591 I have found you one. Buddy of mine has one. Just let me know.
Old Jan 23, 2008 | 06:59 AM
rexbd's Avatar
It was the computer. I will start a new thread with latest list of problems.
Old Jan 28, 2008 | 12:22 PM
Eggcellent's Avatar
ORIGINAL: rexbd
So how did you fix it and how much did it cost? I think I have the same exact problem.
Old Jan 28, 2008 | 02:07 PM
rexbd's Avatar
I looked at a couple of the places mentioned on the Stealth316 website. I selected Foreign Auto Computer, I sent them the unit they checked it out, fixed it and sent it back all for around $200. My mechanic charged me an hour to screw around and make sure every thing was cool with the car after the computer came back. Seems to be running fine.
Old Jan 28, 2008 | 03:05 PM
Eggcellent's Avatar
Is it hard to take the part out? What does it look like? Any ideas as to how I can determine if my ECU needs to be repaired, and how to know this is causing the problem?
Old Jan 29, 2008 | 12:24 AM
mxmikie's Avatar
check the coolant temp sensor
Old Jan 29, 2008 | 04:24 PM
gmarc68's Avatar
mines in the shop for the exact same reson. and im getting a new computer for 230. all sensors and wiring were connected and everyting was good so i think it should be working tomarow. but it was your computer after all??? and is it running good???
Old Jan 29, 2008 | 05:17 PM
Eggcellent's Avatar
ORIGINAL: gmarc68
How did you determine that's what the problem was? I dont feel like fixing the ECU for 200+, then come to find out that wasnt the reason for this problem.
Old Jan 29, 2008 | 07:18 PM
gmarc68's Avatar
it wasnt the feul for sure cus the fuel pump turns on and the injectors throw. and becuz the coils, cranksenor, computer wiring and all sensors were attached and active. just no spark was coming out of the coils.(they grabbed another workin coil and replace it with mine, and wen it didnt spark either, they put my old one back) and they cleaned out my injectors, and one other peice they replaced as well that showed no sign of activity either. so after ruling all other things out, the ecu is the only other module that is connected to all of them. and plus if it isnt the computer, the owner and manager at autozone are good friends so he said for me not to worry about an exchange if i have to. p.s. get a reliable mechanic before you start trusting him with your ride.
bruceriebe
Jul 5, 2010 05:15 PM
Matt1520
Apr 21, 2009 11:46 PM
jyounadim
Nov 24, 2008 02:43 PM
miken68
Sep 20, 2008 09:37 AM
micahman
Jun 12, 2006 11:53 PM
