transmission issue...I think
Old Jan 9, 2008 | 07:05 AM
kimos3000gt's Avatar
Default transmission issue...I think
I drive a 91 3000GT NA. I have about 155,000 miles, engine rebuild at 120k. Recently, I have had a sound coming from what I believe is the transmission. When I take my foot off the gas, and take the load off the engine, a low pitched humming noise occurs (grinding may be a better description). When I turn to the left or right it will go away, when I brake it will go away. I had it into a shop and they diagnosed it as possibly two things. One being, when you let off the gas something in the transmission/transaxle will "spin backwards", this is wearing and creating the noise (they felt this was the most likely)? The other being the bearings where my front axle inserts into the drivetrain. Can you give me an opinion based on what I have stated?
The other question, if I replace the transmission, is the transmission and transaxle the same thing? If not, do they come as an integrated unit?
Thanks for your assistance.
Old Jan 9, 2008 | 09:31 AM
cruisingthesouth's Avatar
Default RE: transmission issue...I think
Is your car an automatic or manual? And you said it is a non turbo right?
Old Jan 9, 2008 | 09:38 AM
It is a manual...nonturbo.
I recently found a manual trans out of a 92 3000gt that has 44k miles on it. below $1000, I am contemplating it.[&:]
Old Jan 9, 2008 | 02:37 PM
I am sure thatIfind you one cheaper than that.
jvsutton
19
Apr 13, 2009 01:26 PM
BlueEvoV
Mar 10, 2009 03:10 PM
ryan97gs
Jan 16, 2009 11:37 AM
kanse
Sep 1, 2008 08:11 PM
seanxmadriaga
Jun 19, 2007 08:52 PM
