wanted turbo info for vr4
The supporting modifications are listed in the second link I believe. It is our basic recommended set-up if you are looking to run it up to 600AWHP. However, it can be tailored to your specific needs/goals for the car.
This does not take into account basic maintenance that may need to be done to your engine, and/or drivetrain reinforcement. You are a 5spd, so, a transfercase bracket (or billet transfercase housing), and hardened output shaft are a necessity.
Kit includes the following items
GZP 747 Billet TD04 Turbos
PTE 680cc Fuel Injectors
Walbro 255HP Fuel Pump
Fuel Pump Hotwire Kit
MAF-T w/3.5 GM MAF
GZP Front Mounted Intercooler Kit
South Bend DXD Stage 3 Clutch Kit
Blitz DSBC Electronic Boost Controller
AEM Methanol Injection Kit
HKS SQV Style BOV
Tanabe Blue Style Exhaust
MAF-T w/3.5 GM MAF
HKS SQV Style BOV
You're a 93, so you already have the forged crankshaft, metal headgasket, and 4 bolt block. Just make sure it has the basic maintenance up to date, and you should be just fine.
I received your email, I will reply a little later this afternoon.
i don't know what your intercooler set up looks like, but, you'll at least want an aftermarket y pipe, as the stock one will blow off the second you start boosting on anything bigger than 9b's.
-so you'll want a y-pipe that you connect to the throttle body with a coupler.
-your intake pipes (the pipes that go from the bubble that connects to the filter THAT run into the cold side of the turbos. price matched parts sells a set for 100 bucks, and should come with couplers.
all three of those pipes will blow off once you turn up the boost.
good luck!
_isiah
good luck!
_isiah
