Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
How do i take my Alternator out. 1994 Diamante
Old Oct 8, 2010 | 06:46 AM
k1th's Avatar
Default How do i take my Alternator out. 1994 Diamante
I know how to do all the work so im good on that part, however yesterday i spent about 4 hours sitting in the rain trying to unbolt my alternator which seems to be extremely hard considering you only have about 2 inches of room to work. SO i finally get it out and it can move free but i cant get it out! its just stuck inside enclosed by my brake lines, Bracket coming off my engine, and my axle. I have no clue what to do i tried unbolting my engine mounts and raising my engine but i still need another inch. I was thinking about just doping my axle out. HELP! this sucks i miss my wanna be bmw.
Old Oct 24, 2010 | 05:43 PM
97LS's Avatar
What engine do you have? I have a 97 LS but have a manual for the 94. Here is what it says about the 1994 alternator removal:
Alternator removal 3.0L SOHC and 3.5L
1. Disconnet negative battery cable
2. Disconnect and remove air intake hose.
3. Loosen tensioner pulley and remove belt
4. On California models, remove rear bank converter assembly
5. Remove engine roll stopper stay bracket
6. On 3.0L engine, remove EGR pipe and disconnect the EGR temperature sensor wire
7. On 3.0L engine, remove intake plenum stay bracket
8. Disconnect alternator wiring connectors
9. Remove alternator from beneath vehicle.
Old Aug 18, 2013 | 08:58 PM
zatale24's Avatar
How did you finally get the alternator out? I have a 3.0 DOHC ('94 LS) and the alternator is free, within the area behind the engine (above axle), but I can't figure out how to get it down. The literature I've seen says to remove the mounting bracket. I've removed bolts that appear to hold the bracket, but it doesn't budge. This isn't my first alternator change out, but it is my first on this model and I'm unimpressed with the mounting location. Can anyone help?
Old Aug 19, 2013 | 06:23 PM
97LS's Avatar
For the '94 3.0L DOHC, here's what my manual says:
  1. Disconnect the negative battery cable.
  2. Remove the headlamp washer reservoir tank.
  3. Remove the condenser fan and upper radiator insulator.
  4. Loosen the tensioner pulley and remove the alternator drive belt.
  5. Remove the alternator upper and lower mounting bolts.
  6. Remove the alternator support bracket mounting bolts.
  7. Remove the alternator support bracket from the vehicle.
  8. Disconnect the alternator wiring harness.
  9. Remove the alternator from the vehicle. To install:
  10. Install the alternator to the vehicle and connect the wiring harness.
  11. Install the alternator support bracket to the vehicle and tighten the bracket mounting bolts to specifications.
  12. Position the alternator on the mounting bracket. Install and tighten the mounting bolt and nut to 17 ft. lbs. (24 Nm).
  13. Reinstall the drive belt and adjust the tensioner until the proper belt tension is achieved.
  14. Install the upper radiator insulator and condenser fan.
  15. Install the headlamp washer reservoir tank.
  16. Connect the negative battery cable and check the charging system for proper operation.
uatuner
Jan 23, 2013 11:29 PM
kornkid1215
Apr 6, 2006 11:45 PM
djbeefyaz
Mar 10, 2006 12:07 PM
bedjemp
May 19, 2005 02:02 PM
