Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
starter grinds when starting
Old Aug 12, 2006 | 02:07 AM
ajsdad's Avatar
Default starter grinds when starting
Hey all, I have a 94 diamante 3.0 dohc - every time you go to start the car it grinds. I have replaced the convertor/flywheel twice, starter twice (last one was from the dealer) still grinds. I even replaced the transmission and conv/flywheel from a 95 diamante and it STILL grinds. Anyone have any thoughts on this? i have sunk alot of time and MONEY trying to cure this problem. Any thoughts would help ajsdad
Old Sep 4, 2007 | 07:31 AM
rubehayseed's Avatar
Default RE: starter grinds when starting
Are you sure you've got the right starter for it? If so, maybe you could shim it. Sounds like it doesn't have proper clearance.
Old Sep 4, 2007 | 11:25 AM
Its the starter. I had the same thing on the GST. Tried changing it? If it still works you might just want to keep it until it actually stops functioning
Old Dec 15, 2007 | 10:24 PM
mxmikie's Avatar
what kind of shape is your battery in ???? 4/5 years old ????
Old Dec 15, 2007 | 10:59 PM
Might also be your TOB
Old Dec 16, 2007 | 09:06 AM
dsm1990gsx's Avatar
ORIGINAL: Sebba
Its an auto
Old Dec 16, 2007 | 09:09 AM
dsm1990gsx's Avatar
It sounds like you either have clearance issue or the wrong starter installed on the car. When you pulled the trans was threre a spacer on the engine block?
Old Dec 16, 2007 | 10:54 AM
I really need to start reading more
Calijim
Jan 17, 2013 04:35 AM
Willhound
Jun 20, 2010 09:20 PM
3000gtkid
Dec 6, 2008 07:57 PM
bacardi
Apr 11, 2008 06:18 AM
Flipz
Dec 12, 2004 04:51 PM
