Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
Transmission Fluid for the F4A51
Old Apr 18, 2009 | 04:12 PM
GTO_VR4's Avatar
Originally Posted by darcymicro
Drianing and refilling the fluid is needed on yours but will not remove the failsafe mode operation. Generally this happens when the control unit gets coolant on it; this is not an inexpensive item to replace so shop around at JY's for a good used one.
Well you said it. Replacing the fluid did NOT remove the failsafe mode. I also did find coolant on top of the TCU. As I stated in my previous post, I pulled the plastic sheets up from the TCU and didnt notice any dried or wet coolant on the TCU itself.
Is there anyway to maybe reset the TCU? or what about getting it diagnosed?
EDIT - Anyone know where the A/T relay is located?
Old Apr 20, 2009 | 05:36 PM
Manybrews's Avatar
replace the AT relay... Its soaked with coolant and ruined.
replacing the fluid will fix nothing. replacing the fluid is for maintenance only, to prolong the mechanical parts.
then fix your coolant leak.
Old Apr 21, 2009 | 11:46 AM
GTO_VR4's Avatar
Do you know where the AT relay is located?
Old Apr 21, 2009 | 06:49 PM
Manybrews's Avatar
if you were looking at the TCM from the passenger side, you were looking right at it.
Old Apr 22, 2009 | 12:10 PM
GTO_VR4's Avatar
yep, found it. To the right of the TCM. E8T101 2218. I found it soaked with coolant! I dried the connector and the relay itself and my transmission is still in fail safe. I also unplugged the relay with the car running and nothing changed, so chances are I really just need to replace the relay.
easier said than done. I called the big 4 in my area, NAPA, autozone, advanced and the junkyard. None of them have it. I still want to hold back on calling the dealer for a bit. I checked online, nothing.
You guys are my last hope before calling the dealership. Does anybody know where I can find a TCM relay
Old Apr 22, 2009 | 01:35 PM
GTO_VR4's Avatar
OK guys, I managed to get rid of the fail safe mode. pretty much by letting the relay and connector dry overnight. I'm back in business. Thanks for all the help guys!
srinath
Dec 4, 2013 12:21 PM
newoutlanderfan
May 27, 2013 10:47 AM
GTO_VR4
Apr 12, 2009 08:54 PM
jtsharp
Apr 23, 2008 06:19 AM
jcasaccio
Jun 6, 2006 06:14 PM
