Mitsubishi Eclipse & Eclipse Spyder For years, the Eclipse line has stood for cutting edge styling and performance at an affordable price.
keeps fusing out!!!
Old Nov 8, 2015 | 08:56 PM
tancash's Avatar
Default keeps fusing out!!!
Hello i own a 98 eclipse gs spyder convertible all stock changed nothing!!find out my tail lights,dash board lights,parking lights,and license plate lights all went out😠checked all my fuses nothing!!maybe a short somewere?maybe a relay?please somebody help me...
Old Nov 8, 2015 | 09:01 PM
Guyfromhe's Avatar
Did you try messing with your light control switch? That could be the culprit too...
If it was somehow switched to OFF or stuck there because the switch wore out it could be the problem...
If there was a short you'd expect a fuse to pop and I don't think all those things would be on the same relay, specially the dash lights.
Old Nov 8, 2015 | 09:06 PM
tancash's Avatar
Nah it didnt check that...wow...but i replaced the tail light fuse twice and it kept burning out! so could it be theres a ground wire somewere thats touching metal?
Old Nov 9, 2015 | 09:06 AM
Guyfromhe's Avatar
You didn't say that the taillight fuse was burning out... That probably says you have a short somewhere...
You would need a wiring diagram to properly check the whole circuit... I'd check at all the lights for bare wires or loose bulbs, could also be inside the switch.
Does the fuse burn out instantly?
Skiddy
Aug 24, 2009 08:18 PM
susie22
Nov 19, 2007 09:16 PM
zeanimal2001
1st Generation
Aug 11, 2007 11:53 AM
brandoN^gsT
Feb 3, 2006 01:02 AM
jaymes96
Nov 4, 2004 07:26 PM
