2005 Endeavor Transmission Shifting Problem
Old Mar 22, 2022 | 11:32 AM
Alfred Alarcon's Avatar
Default 2005 Endeavor Transmission Shifting Problem
My 2005 endeavor LS - V6 - 3.8L 3828ci GAS MFI vin S type 6g75 - 4 valve SOHC
when i put the car into reverse it doesnt move unless i accelerate a little bit and it catches for a second or two reverses a few inches and stops moving again, it does the same while in drive, when im shifting between drive, neutral, or reverse i can feel it catching gears but the car wont move. I've seen multiple videos on youtube saying it is possibly the filter, and possibly a solenoid or sensor, im just not sure what i can be, im not experienced with transmissions at all but i have mechanical experience, im just hoping a replacement of a solenoid, sensor, or filter will have my car back up and running, thank you in advance for any helpful advice.
Old Mar 23, 2022 | 10:43 AM
whilst01's Avatar
Default transmission trouble
Hi. > How many miles on car? Service history?
> Have you checked fluid level? Condition? "Bright pink/red or dirty?"
> Can try a drain and fill,see if that helps. Do NOT do a 'Fluid Flush'!
HTH. Report back. Jeff
Old Mar 23, 2022 | 11:50 AM
210k, I'm not sure about servicing on the transmission or fluids, I've personally never done anything to help the transmission, the level and conditions of fluid are good but I will try drain and fill
Alyria
May 18, 2021 04:53 PM
Alyria
May 17, 2021 06:40 PM
NEDU-MCHILLS
May 19, 2020 01:45 PM
bengiesosa
May 19, 2020 01:34 PM
Adam Mikkelsen
Sep 20, 2019 12:58 AM
