Endeavor 2005 transmission problem
Old Feb 11, 2020 | 09:03 AM
bengiesosa's Avatar
Default Endeavor 2005 transmission problem
I have a 2005 Endeavor. The letter N start blinking after the 2 gear and does not change. Any idea of what happening?
Old Feb 13, 2020 | 11:27 AM
dnwoll's Avatar
Flashing "N" light is an indicator of a a Fail Safe mode. PCM detected some malfunction in the transmission and places vehicle into the "Fail Safe" mode. It allows you to drive slowly (1, 2 nd gear), but not full speed on highway. Many reasons for this, from simple wiring/harness issue to some major internal failure or actual PCM malfunction. You may have to have a mechanic scan the PCM with appropriate scanner to at least pull Transmission DTCs.
Old Feb 17, 2020 | 10:01 PM
me262's Avatar
Default Trans prob
Have you done anything recently to the transmission? I change the fluid in mine and had a major problem with the car going into limp home mode. My problem was I had over filled the transmission by just maybe a pint. When I took a pint out it acted okay again. You have to use the exact fluid as well. You can get it from Amazon under a different name I think Honda? But it's cheaper than buying Mitsubishi fluid. Same stuff I think.
Old May 19, 2020 | 01:34 PM
Billoka10's Avatar
josuebasurto
josuebasurto is offline
DefaultQuote:
Originally Posted by NEDU-MCHILLS View Post
Dear friends, I am having an issue with my endeavor. The Neutral light flashes while the car is in motion. Also When the car is pushed on reverse, it jerks before moving.... I need your advice. NEDU
I'm having a similar problem, My Mitsubishi Endeavor 2005 was been driven by me normally in a highway around 100km/h (60mi/h) and suddenly felt like a stopngo and after that transmission was on 3rd and neutral light flashing.
bengiesosa
bengiesosa is offline
Default Endeavor 2005 transmission problemI have a 2005 Endeavor. The letter N start blinking after the 2 gear and does not change. Any idea of what happening?
"Please, I have the same problems with my 2005 Mit. endeavor blinking N and NO POWER for acceleration. Any person with a helping ideas will be greatly appreciated".
NEDU-MCHILLS
May 19, 2020 01:45 PM
Adam Mikkelsen
Sep 20, 2019 12:58 AM
dc59
Jan 24, 2016 11:49 AM
guangui
Jun 29, 2012 06:55 PM
