2005 wont start, but cranks good
i drove it all day, went out to get into it and tried to start it and nothing.
it cranks strong. no way the battery, but its not even chugging to start.
it had been running perfect up until this.
when i try to crank it i can hear something in the back click.
im assuming the fuel pump?
if i pump the gas i can get a SLIGHT, and i mean SLIGHT chug out of it
almost non-existent.
someone has had to deal with this before =(
thanks
thanks
Won't make a difference with bad cam sensor but a bad MAP sensor will prevent it from starting! Simply pull the lug on the MAO sensor. Sounds more like 180 degrees out between the cam and the crank or a bad wire to fuel pump, crank sensor or ECM or a security issue perhaps. That will show up as a flashing key or security symbol. General info. May help.
Won't make a difference with bad cam sensor but a bad MAP sensor will prevent it from starting! Simply pull the plug on the MAP sensor. Sounds more like 180 degrees out between the cam and the crank or a bad wire to fuel pump, crank sensor or ECM or a security issue perhaps. That will show up as a flashing key or security symbol. General info. May help
95HGeclipse
Mar 5, 2007 10:42 PM
