2005 wont start, but cranks good
Old Mar 30, 2014 | 09:42 AM
mellowjamie's Avatar
Default 2005 wont start, but cranks good
i drove it all day, went out to get into it and tried to start it and nothing.
it cranks strong. no way the battery, but its not even chugging to start.
it had been running perfect up until this.
when i try to crank it i can hear something in the back click.
im assuming the fuel pump?
if i pump the gas i can get a SLIGHT, and i mean SLIGHT chug out of it
almost non-existent.
someone has had to deal with this before =(
thanks
Old May 25, 2014 | 10:08 PM
Hon450's Avatar
How many miles? Last t belt replacement? If you take the intake tube off and spray some startling fluid in and it starts or tries you got a fuel issue. Possible cam or crank sensor too
Old Jul 16, 2017 | 12:43 PM
Bobby Poirier's Avatar
Won't make a difference with bad cam sensor but a bad MAP sensor will prevent it from starting! Simply pull the lug on the MAO sensor. Sounds more like 180 degrees out between the cam and the crank or a bad wire to fuel pump, crank sensor or ECM or a security issue perhaps. That will show up as a flashing key or security symbol. General info. May help.
Old Jul 16, 2017 | 12:45 PM
Won't make a difference with bad cam sensor but a bad MAP sensor will prevent it from starting! Simply pull the plug on the MAP sensor. Sounds more like 180 degrees out between the cam and the crank or a bad wire to fuel pump, crank sensor or ECM or a security issue perhaps. That will show up as a flashing key or security symbol. General info. May help
gsnate
Jul 16, 2017 12:48 PM
Johnboy13
Oct 25, 2010 06:07 AM
cod1ak
Mar 28, 2008 08:55 AM
95HGeclipse
Mar 5, 2007 10:42 PM
Dookitchen
Apr 14, 2006 02:32 AM
