Car will not start...
Old Sep 11, 2015 | 09:02 PM
Alexwallace23's Avatar
Default Car will not start...
Yesterday the check engine light came on as soon as I turned the car on and the engine started to lightly vibrate. This problem happened about a year ago and the fix for it, based of the CEL code, was to replace one of the coil packs. This time around I can't get the CEL code because the car turned off before I could get the code and now the car won't start. So, I'm assuming it's another bad coil pack. One of the coil packs on the front row was extremely hot compared to the other two. There was also a weird smell, almost like a burning smell, coming from this coil pack/spark plug. I replaced this coil pack and the spark plug but the car still will not start.
So, is there a way to get the CEL code without turning on the car or anyone have any ideas as to what's going on here?
Old Sep 12, 2015 | 07:39 AM
jenyy45's Avatar
Phen375 is reasonable five magical elements unique combination, all components that take into account factors increase enzyme. This gain 5 enzyme work together in a unique way to control appetite, switch to clock body fat burning machine. Try to Phen375 today and you'll see quick results. Not only are we seeing the weight loss of 3-5 pounds a week, and Phen375 appetite suppressant and make you feel better about yourself. If you are feeling down because of problems with weight, I tried all the weight loss decision to no avail, and give it all Phen375 requires moral support, and weight loss.
Old Sep 12, 2015 | 09:32 AM
Guyfromhe's Avatar
The car has to be in the on position not running to scan it....
Old Sep 13, 2015 | 04:59 PM
I guess I need to go get a wired OBD II scanner since the bluetooth scanner I have now won't power on unless the car is running.
Old Sep 13, 2015 | 07:14 PM
Guyfromhe's Avatar
I have a Bluetooth scanner and it works fine with engine off, key on...
Make sure you aren't just turning it to accessory... It has to be ON... your windows should work, and your climate control system should be active if it's in ON...
In fact my bluetooth scanner will work with the car off completely (I can find it and connect to it) but I can't talk to the car.
What app are you using?
Old Sep 13, 2015 | 08:34 PM
I have the Garmin Mechanic OBD scanner and it will only work with the car running. I just bought a wired OBD scanner from Auto Zone and I was able to get the codes. I am getting codes P0223 and P0123. Both refers to the throttle position sensor.
Any ideas how to troubleshoot the throttle position sensor?
Old Sep 14, 2015 | 09:08 AM
Guyfromhe's Avatar
What year?
Does it have a throttle cable or is it drive by wire?
Old Sep 14, 2015 | 07:52 PM
What year?
It's a 2005 and the problem was resolved today. A mechanic took a look at the car and it turns out a blown fuse prevented the car from starting. This actually sucks because I now have to pay this guy to replace a fuse.
Old Sep 14, 2015 | 07:54 PM
Just for my knowledge, how can I tell if it has a throttle cable or drive by wire?
Old Sep 14, 2015 | 08:51 PM
Guyfromhe's Avatar
Hey at least your car starts... I hope he didn't charge you that much to diagnose a blown fuse though...
Look at the accelerator pedal is there a cable attached to it that moves or just a little wire connector?
Also under the hood do you see something that looks kinda like a bike break cable?
At 2005 it probably doesn't have a throttle cable...
arupc66
Feb 12, 2013 10:02 PM
gm12111
Sep 6, 2008 08:52 PM
ajcoolman
Sep 24, 2006 03:49 AM
galant_girl
Sep 27, 2005 10:29 PM
chrome0011
Feb 29, 2004 11:46 PM
