Coolant leaking from behind engine
Old Mar 22, 2024 | 02:06 PM
bfsavoo's Avatar
Default Coolant leaking from behind engine
I just got my tranny replaced, and had no pre existing issues beforehand. Now my overflow hose is missing (not sure if that has anything to do with this), and there's a metal line right behind the oil pan, that has coolant dripping off of it. I refilled my coolant to right below the overflow, and it just drips out and temps get super high. I've tried squeezing the radiator hose and it's not very pressurized, anything anyone? I just need some tips and clues here honestly
Old Mar 23, 2024 | 10:15 AM
whilst01's Avatar
Default coolant leak
Hi. I assume you had it replaced at a shop.?
If so, they should remedy situation. > Replace overflow hose and radiator cap.(factory)
Mine leaks there a little as well. I have not delved into it further as of yet.
It is a 'banjo' fitting so, should be able to replace crush washers and torque properly.
Best,Jeff
Old Mar 24, 2024 | 09:16 AM
bfsavoo's Avatar
Best,Jeff
So, from what I've heard, this is the transfer case coolant line. They discontinued it, anyone got any idea if this is even fixable? There's 2 or 3 sliver cracks that rusted out on the line. There's no way to get any OEM line for this, they discontinued it so I need to find another way around this. Anyone got any tip or clue what to do?
Old Mar 24, 2024 | 09:25 AM
whilst01's Avatar
Oooh.
Yep,that's the one.
Well, get a mini tube cutter and cut out a couple few inches.Find coolant type rubber hose and with bolts that fit in tight; cap it off both sides.....
Or: Pick a Part and get a replacement that's probably just as bad...
I'll have to inspect mine further as well as that system.
Best.
Old Mar 24, 2024 | 09:26 AM
bfsavoo's Avatar
Ahhh damn. I was hoping it wasnt true.. Alrighg, do you think cutting it and putting rubber hose on there with some clamps would be the best choice here? I need my endeavor bad cus it's snowing bad where I'm at right now.
Old Mar 24, 2024 | 09:28 AM
whilst01's Avatar
Should work.
bfsavoo's Avatar
Sounds good, I'll update when the jobs "finished" lol.
Old Mar 24, 2024 | 09:29 AM
whilst01's Avatar
Where are you? Up in Northeast or upper Mid West?
Old Mar 24, 2024 | 09:30 AM
bfsavoo's Avatar
Upper midwest, Minnesota specifically
ruski
Dec 30, 2010 05:32 PM
Khaz
Apr 22, 2008 10:10 PM
Killer
23
Nov 13, 2007 05:08 PM
novetek
Feb 20, 2006 04:16 PM
jmac
Jun 5, 2005 12:54 PM
