Steering Problem
Old Mar 16, 2014 | 04:15 PM
TechnoGeek's Avatar
Default Steering
Originally Posted by Sebba
Or your lower control arm bushings. Push down on the fender and see if you get a squeak.
I checked for a squeak, No squeak. I appreciate the effort to help me find a solution.
I quizzed her again and she now says it didn't growl it makes a squeal noise.
I checked the Belt, doesn't appear to be any issues there with slipping. looks in good condition. I talked to a guy who recommended I change the Power Steering fluid since it has never been done.
can't seem to find much info on this process. I did read one forum post saying to:
1. Empty the Reservoir.
2. Disconnect the lowest hose that is larger and is the Suction hose to the pump.
3. Lower the hose lower than the Steering Gear Assembly and let it drain.
The system holds 1.3 quarts so hopefully I get most of it.
4. Reconnect Suction Hose and fill reservoir.
5. Steer Full Right and Full Left a few times and check level again.
Sure wish I could find a Service manual to download.
guess this will have to be a discovery project.
the Haynes manual at the Library seems to miss stuff like this.
Old Sep 16, 2014 | 03:23 PM
jbteehee's Avatar
Anyone thought of the power steering pressue switch?? Good luck finding one!!
TRUOMEGA
Dec 9, 2021 05:20 AM
Grahms_eH
Mar 23, 2007 10:45 AM
newspeed
Mar 16, 2006 01:59 AM
newspeed
Jan 15, 2006 01:30 PM
R3M3DYZ
Sep 10, 2005 01:12 PM
