Timing Belt Change in Endeavor at 84000 miles
Old Nov 23, 2010 | 05:47 PM
gagan@candgdistributors.ca's Avatar
Default Timing Belt Change in Endeavor at 84000 miles
the dealership is suggesting a timing belt change at 84000 miles, do I need to get it done or can I wait till 100,000 miles
thanks
Old Nov 24, 2010 | 04:00 PM
4never's Avatar
If you look into your owner's manual, it'll state 60,000 as a preventive maintenance for TB but you could probably push it to where you are at now (84000), but 100000 is pushing the limit.
Old Nov 24, 2010 | 10:18 PM
JOSE A. RODRIGUEZ's Avatar
Default Cambio de correa del tiempo
Te recomiendo que quites la tapa y veas la s condiciones de la correa, realmente te sugiero que la cambies, pero eso esta a opcion tuya, si no la puedes cambiar por lo menos revisala, a ver si no esta rasgada por el desgaste, suertew conb eso. Jarg.
Old Nov 26, 2010 | 11:59 PM
jgbrules's Avatar
your living on borrowed time. 60k is the mileage interval. if you got 84 consider yourself very lucky. pay $500.00 for a timming belt change, or when the belt breaks pay 2-3 thousand to remove the heads and replace all the bent valves. your choice!!!!
frankmanic
Oct 2, 2011 10:08 AM
Adamiecjr1
May 23, 2009 11:00 AM
8000RPMS
Aug 30, 2007 05:49 AM
tj90
Sep 20, 2006 01:57 PM
rmplstlskn
Jul 18, 2005 07:11 PM
