Water leak while A/C is on
#91
fullecm,
You are going about it wrong. You have to drill the hole in the lower side of the box 1st on the drivers side. Then put some 1/4 O.D. refrigerator tube through the hole you drilled in the box, then thru the drain tube, then feed it thru the hole in the firewall reinforcement. Then use that as a guide for your 90degree tube. You wont need a lift if you are doing it correctly.
email me at that email in my last post on page 9 and I can help you out. I am pretty handy with cars and stuff but it isnt hard to do this if you are doing it right. It is just tedious and takes about 3 hrs to complete beginning to end. Maybe less
#93
I had the same problem until today - here is the solution --
-- open the driver's door
-- locate where the air conditioner blower box is attached to the passenger side of the firewall – look to the immediate right at the top of the gas pedal arm
-- condensation flows toward the front of the vehicle through the firewall at the leftmost edge of the air conditioner blower box - see photo #1
-- open the hood and stand next to the front wheel on the driver's side
-- look down at the firewall over the battery and to the passenger side of the brake master cylinder
-- locate the small diameter metal tubes running horizontally and attached to the engine compartment firewall
-- locate the hole in the engine compartment firewall panel behind the small diameter metal tubes - see photo #2
-- this hole leads to the drain opening in the air conditioner blower box mounted in the passenger compartment
-- follow the brake tubes as they run from under the vehicle and turn toward the front wheel on the driver's side
-- locate the hole in the engine compartment panel behind the brake tubes
-- insert a short length of stiff wire into the hole through the engine compartment panel to unblock the drain hole
HTH,
driver
HTH,
driver
#94
Discovered same problem with my 2004 Endeavor in October of 2012. Had extended warrantee and it cost $1,017 to repair. Pulled out my mats to clean them last week and noticed same water problem. I had 72,000 miles when I repair was done by Mitsubishi and had 83,000 miles when I discovered issue again. Mitsubishi said their warrantee was for only a year. Since they did the original repair my auto air hasn't work properly. I will try DRIVERS fix. I can'r see spending another $1,000. Obviously the problem only happens in the summer.
