clutch replacement
Old Aug 2, 2006 | 04:27 AM
rodrigo.diaz3's Avatar
Default clutch replacement
Hi im From Chile and i own a 2006 evo ix my clutch is fading i want to replace it will be the exedy organic a good choice im not good doing drag race.
I really appreciate your help.
Old Aug 29, 2006 | 07:23 PM
Mike21's Avatar
Default RE: clutch replacement
I'm guessing that the choice of what clutch to use also depends on how much power due to mods you goanna have. If I had to upgrade my clutch without any modifications, I would simply go with an ACT stage 1 or mabye a single plate from exady. On the other hand, if there is plans for heavy modifications which would definately give you big dyno numbers at the wheels, a stronger clutch would be good. Mabye a twin or triple plate from exady or an ACT stage 3 or something like that.
Old Aug 29, 2006 | 09:02 PM
XTREME's Avatar
Go with the ACT clutch..!! Exedy is good too but if you go with that company you don't need the twin clutch unless you have some serious horsepower!!
Old Aug 29, 2006 | 09:06 PM
ACT is best for DSMs but for EVOs the best is Exeddy and YES you can race with it and use it for street
Silvertooth
May 22, 2007 09:40 AM
mcguffp
May 9, 2007 03:08 PM
wicked2407
Oct 25, 2006 06:07 PM
92inprogress
1st Generation
Jul 30, 2005 07:18 PM
Rod_SpyderGT
Oct 18, 2004 09:26 PM
