02 Galant. MANY PROBLEMS!!! HELP!
Old Feb 8, 2007 | 09:11 PM
TheKid's Avatar
Default 02 Galant. MANY PROBLEMS!!! HELP!
Sup guys. I couldn't find my old thread but this is the follow up. Here is a review of the problem so far. Engine hesistates, engine/car vibrates when stopped. Changed Timing belt and seals and other crap. BAD Mechanics. Never ever go to Car Aid in Tustin, CA
So far... Engine vibrates crazily above 5000RPM. The car vibrates when it is at idle. you can see the glove box vibrating.
The car had a Check Engine light. The code was P0304 but we switch the igniton coil and now its P0302. So #2 cylinder is misfiring. We bought a new coil for that #2 cylinder, and still hesitation. Any help? New sparkplugs too and gapped correctly.
The car has 153,000 miles. Everything stock. I went around Google and got some ideas. Bad oxygen sensor, bad cat, or bad fuel injector. I cleaned all the injector except #2. (hard to read) I'm planning to put in the Chevron Gas treatment to see if it works. Then going to flush it at Jiffy Lube or something.
So any suggestions? I need it by friday.
Old Feb 9, 2007 | 08:21 PM
TheKid's Avatar
Default RE: 02 Galant. MANY PROBLEMS!!! HELP!
Bump anyone? Anything at all.
Old Apr 28, 2012 | 03:12 PM
Galanthighspeeder's Avatar
Did you try replacing Fuel Injector #2??
Old Sep 18, 2012 | 12:44 AM
armikel07's Avatar
Your balance shaft belt is broke.
Old Nov 3, 2012 | 10:29 PM
Jacsdaman's Avatar
I've had a situation where a coil went bad. Because it was bad it also toasted the computer for that coil. I learned that any time you have a coil go bad you almost always need to replace the computer at the same time because the computer may be short out and it could also have short out the new coil. Hope this helps, but definitely hope this isn't your problem. Good luck
Old Feb 10, 2013 | 01:05 PM
tecnico713's Avatar
Default 2002 Galant maps
Hi, need information about 2002 Galant v6 automatic transmission flash maps and bin to correction gears shift ratio or the bin address to modify. Thanks and appreciate your attention
Old Mar 4, 2013 | 12:55 PM
curranz69's Avatar
My car has some vibrations also. Mostly just before the engine warms up. After that, its barely noticable. Any tips for me ?
MyEclipse
37
Jun 12, 2017 11:36 PM
fizzwhiz1
Jan 7, 2011 04:54 PM
dwayotte
Jan 27, 2009 01:01 AM
IwantTOgoFAST
Nov 6, 2007 12:59 AM
TheKid
Feb 7, 2007 08:56 PM
