03 Galant 2.4 Stalling Problems
Hey guys new to the forum kind of ran out of ideas so I needed some help to get my car running again. Heres my story few weeks ago on cold start up the motor would rev up to 3k and decrease slowly and when turning on when hot it would idle so low that it would want to die. So I decided to give it a tune and replaced plugs and wires. I also did some research and thought Id clean the MAF sensor and IAC valve with that CRC cleaner which was probably a bad idea. Anyways after the tune up and cleaning I started the car and it blew alot of white smoke probably cause of the cleaner since I sprayed in the throttle body but was idling fine. As soon as I put in reverse it died and kept on trying to die after I started it so my genius thinking altered the idling bolts on top of the intake manifold so it would hold the idle cause I kind of figured I messed up the IAC valve when I cleaned it. That only worked for a couple of days until the car would start and then just die in seconds. I decided to buy a New IAC Valve from Ebay and replaced it and positioned the idle bolts where they used to be. I started the car and it still doesnt want to start and Im completely baffled now. Ive been googling alot and have read that I might have messed up the TP Sensor or the MAF sensor or even the PCM or the PCM needs to be reset not really sure. I would really appreciate some help as this has been driving me mad. Thanks for reading my story and any input
Also if I hold the accelerator pedal down before starting I can get it to run but it runs really bad and tries to die. I also read up on the immobilizer needs to be reprogrammed because I disconnected the battery. Thanks for the help
ncmountie
Nov 7, 2019 11:54 AM
fredij2004
Jun 2, 2009 02:57 PM
