1999 2.4 stalls at normal temp?
Old Aug 13, 2012 | 09:14 AM
newbedtazz's Avatar
Default 1999 2.4 stalls at normal temp?
99 Galant with 2.4 a/t.Starts and runs fine when cold,when it gets to normal temp (after a 2-3 mile ride)starts to stumble as if it is running out of fuel and will stall when trying to accelerate.Will re-start but as soon as you try to accelerate same thing happens it will stumble and stall even when in park if you try to give it gas it will stall out.Tach jumps up and down in RPM'S before it stalls even if holding the gas pedal steady in 1 spot.Any suggestions greatly appreciated.Thanks for your time.
Old Aug 13, 2012 | 08:28 PM
mxmikie's Avatar
plugged exhaust
Old Aug 15, 2012 | 12:18 PM
newbedtazz's Avatar
Still plenty of exhaust pressure at the tailpipe when it's stalling out and it will start right back up.I'm leaning more towards something electrical and still trying to figure it out but Thnx for the input mxmikie
Old Aug 15, 2012 | 03:33 PM
mxmikie's Avatar
om your temp sensors check your exhaust with a heat gun
dorian7
Aug 8, 2007 04:53 AM
RamZet
Oct 17, 2006 02:11 PM
aramis79
Oct 28, 2005 05:14 PM
off roader
Oct 21, 2005 06:16 PM
wildwest
Jul 22, 2004 04:31 PM
