2000 stalled now won't start
2000 2.4, My service engine light was on. I took it to autozone. Code was a 0302. I changed spark plugs and 2 of the wires. I believe it's number 4 plug was 3 inches deep in oil. I drove to work (15 mi). On the way home it died at a stop sign about 4 blocks from home and now won't start. Could it be the coil pack from the number 4 soaked in oil.
Its possible, if you found one spark plug covered in oil you have worn piston rings or valve guides and this would certainly cause a misfire causing the car to run rough and hard starting, it would also be easier to stall, however I wouldn't expect it not to start at all.
Probably a seperate issue but the oil problem needs fixing either way.
raycam2kx
02-21-2008 11:08 PM
raycam2kx
14
10-06-2007 08:31 PM
raycam2kx
08-16-2007 08:33 PM
