2000 stalled now won't start
Old Jun 27, 2011 | 05:58 PM
samerm23's Avatar
Default 2000 stalled now won't start
2000 2.4, My service engine light was on. I took it to autozone. Code was a 0302. I changed spark plugs and 2 of the wires. I believe it's number 4 plug was 3 inches deep in oil. I drove to work (15 mi). On the way home it died at a stop sign about 4 blocks from home and now won't start. Could it be the coil pack from the number 4 soaked in oil.
Old Jun 30, 2011 | 11:20 AM
mxmikie's Avatar
i do not think so
Old Jul 1, 2011 | 10:37 AM
HeadsWillRoll's Avatar
Its possible, if you found one spark plug covered in oil you have worn piston rings or valve guides and this would certainly cause a misfire causing the car to run rough and hard starting, it would also be easier to stall, however I wouldn't expect it not to start at all.
Probably a seperate issue but the oil problem needs fixing either way.
Old Jul 2, 2011 | 07:41 AM
samerm23's Avatar
Thanks for the info. I took the timing belt cover off and found the belt is loose. i don't think it is broke because i can't pull it off.
Old Jul 2, 2011 | 12:20 PM
Good luck with the fix keep us updated.
Old Jul 3, 2011 | 12:06 PM
STARKILLER70's Avatar
I had the same problem my plugs covered in oil....I had the idea it could be the gasket around the valve cover, where the plug goes through...or the valve cover may need to be tightened.
Old Jul 3, 2011 | 12:57 PM
They shouldn't need tightening, its probably wear. You will need replacement parts. Take it to a garage and have them check it out because while the plug is covered in oil it will be misfiring and wasting fuel.
xtanmanx
1st Generation
Mar 11, 2008 08:16 AM
raycam2kx
Feb 21, 2008 11:08 PM
raycam2kx
14
Oct 6, 2007 08:31 PM
raycam2kx
Aug 16, 2007 08:33 PM
Electech1
Nov 3, 2006 10:29 PM
