2002 Mitsubishi Galant ES 2.4L Turns over but won't start.
Old Dec 12, 2017 | 12:09 PM
alflor's Avatar
I have an 08 galant and have replaced fuel pump, replaced fob key and had key reprogrammed. Cannot start the car. Gas doesn't seem to be getting to the engine. Does anyone know if the fuel relay pump can fix this problem?
Old Dec 12, 2017 | 02:33 PM
Manda Blair's Avatar
Default Bad engine
I did all that and still wouldn't start, had it looked at tutns out those engines are no good. the gears in my engine locked up and engine was just about gone, would need a new engine and is not worth it. Was told that a lot of these engines from 2002-2008 have the same issue. I had to junk my car. Good luck
Old Jan 14, 2018 | 11:05 PM
Bailey2.4galant's Avatar
It is your timing belt it snapped or does not have ribs anymore from age. I will guarrentee it. Unless you are throwing codes
Old Jan 14, 2018 | 11:10 PM
It is your fuel pump relay or fuse or clogged line or bad injectors or bad fuel pressure regulator. Simple diagnosis is done by pull off line before fuel filter have friend turn key to prime fuel line. If it sprays like fire hose then it is clogged line. If no spray check fuse, then buy relay for 20 or less. If still not spraying fuel pump is either not correctly installed or faulty fuel pump.
Old Mar 16, 2019 | 07:36 AM
BuckeyenPhilly's Avatar
Default Timing belt
It is your timing belt and they have an interference motor so it will cost $2000 to fix. Tow it to the scrap yard and buy a new one. Your valves likely bent when your belt snapped because of the design of this motor. All you have to do is look up interference motor. Good luck.
Daron1245
Mar 3, 2021 02:25 PM
Hollywood1987
Jan 14, 2018 11:12 PM
Drewt1047
Dec 19, 2012 12:55 AM
davedesmo
13
Sep 28, 2007 06:10 PM
travisc020
1st Generation
Jun 14, 2006 09:06 PM
