98 Galant Squealing When Heater and Rear Defrost is turned on
Old 12-03-2008 | 08:23 AM
athlete1012's Avatar
Default 98 Galant Squealing When Heater and Rear Defrost is turned on
He everyone I have a question if you can help me out. Can you tell me what would cause this loud squealing noise when I turn on my hearter or rare defrost. It last for about 2 minutes on and off. Is this a belt issue or something else. If its the belt is it expensive to get fix? [/align]
Old 12-03-2008 | 04:24 PM
Manybrews's Avatar
Default RE: 98 Galant Squealing When Heater and Rear Defrost is turned on
tighten your alternator belt to begin with.
Old 12-04-2008 | 12:29 AM
kweef's Avatar
wait so the belt only squeals when u turn the heater and defroster on?
Old 12-05-2008 | 12:28 AM
Manybrews's Avatar
ORIGINAL: kweef
that would mean a huge electrical load from the alternator, hence the squealing alternator belt.
Old 12-07-2008 | 11:24 AM
tobybul's Avatar
ORIGINAL: Manybrews
I 2nd this. Most likely, alt belt is a bit loose. When electrical load is increased, it affects the alt tesulting in to the squealing.
Old 12-07-2008 | 03:05 PM
kweef's Avatar
ORIGINAL: Manybrews
ORIGINAL: kweef
i was just clarifying what he was tryin to tell us...
Old 09-21-2009 | 10:27 AM
mad2226's Avatar
Default Same Issue
I have the same issue and the belt is pretty tight. could the alternator bearings be bad and when there's a load it makes it squeak?
Harv
02-24-2013 09:36 AM
brendaboo
11-08-2011 10:51 PM
jenniferrotch
08-31-2011 12:59 AM
GTLancer
11-11-2007 10:30 AM
