brake pads
Old Jun 18, 2008 | 05:08 PM
Phredawgy's Avatar
Default brake pads
My mother in law has a 2003 Mitsubishi galant, Auto, and needs her frontbrake pads changed....is this a simple diy procedure? Do the brakes need to be bled?
Old Jun 18, 2008 | 06:38 PM
dsm1990gsx's Avatar
Default RE: brake pads
If your doing the pads should be pretty simple and srtaight forward, you'll need something to push the piston into the brake caliper.
Old Jun 18, 2008 | 09:59 PM
silvercoupe97's Avatar
No, you will not need to bleed the brakes. Just make sure you top off the brake resevoir if it needs to be. But, if you want to bleed it, you can.
Old Jun 19, 2008 | 03:36 PM
Phredawgy's Avatar
thanks guys for the reply. I know on my saturn bleeding the brakes insn't needed for changing the pads but I haven't ever done this on a mitsubishi....and I've never bled the brakes on any car.....not something I want to do unless I have to.
Old Jun 20, 2008 | 06:55 PM
PoolhallJunkie777's Avatar
you really dont have to bleed the breaks on any car if you are changing the pads. now if you change the calipers that is a diffrent story with a diffrent ending
Old Jun 20, 2008 | 09:02 PM
Phredawgy's Avatar
Well it turns out the rotors were a bit grooved because she drove on them longer than she should haveso we had to take it to a shop so they could machine them .... but thanks again for everyones input.
Old Jun 22, 2008 | 08:51 AM
dsm1990gsx's Avatar
Well you could have taking the rotors off and have a shop machine them, would have saved you some $$$.
bhamvett
Apr 8, 2008 01:10 PM
Smola
Jun 13, 2006 09:39 AM
Takumi
Nov 1, 2005 04:22 PM
dolfans
May 19, 2004 12:14 AM
Jacoby
Nov 12, 2003 11:14 AM
