Compressor will constantly cut on and off when you start driving
Old May 27, 2009 | 02:04 PM
BrokeDad's Avatar
I don't think it should change and go that high. Sounds more and more like it's restricted and not moving around the system. Bleeding the high side sometimes will free up a blockage but if it doesn't work you're out the $40 worth of freon. If you do it have a rag handy as there is lubricant in the freon and don't use your finger to push the pin down unless you like minor frostbite
Old May 27, 2009 | 09:13 PM
dsm1990gsx's Avatar
That seems a bit high but I its really hard to diag just by seeing the low side. I could get a better idea if you could get a high side reading.
Old May 31, 2009 | 09:27 PM
jgbrules's Avatar
the low side pressure at idle should be around 28-30 psi. high side should be anywhere from 175-225psi depending on the air temp outside. when you rev it up sounds like the pressures are either going way high or way low, the pressure switch in the a/c system will cut off the compressor if the system has higher or lower pressures than factory specs. did you overcharge the system when u installed the new compressor?? is there a leak and mabey the system is low?? i would start there. good luck. greg....
LostMan
Aug 4, 2010 12:28 AM
alexxei
Aug 5, 2007 02:15 AM
Genosyne
Mar 29, 2007 09:07 AM
vr4luver
Feb 24, 2006 01:19 AM
