Galant 4 cyl timing belt changed..........
Old 09-06-2009, 08:01 PM
les1's Avatar
Default Galant 4 cyl timing belt changed..........
Friday took my galant in for timing belt change. It now has terrible vibrations especially around 1500rpm. Any ideas why this should be & causes.
Any information I would be grateful for I have to return it on Tuesday but I do not think that he really has any idea what the problem is. Thanks......................
Old 09-09-2009, 01:12 PM
mko's Avatar
mko
mko is offline
What year is the Galant? I bet they didn't align the oil pump balance shaft correctly!
Old 09-09-2009, 05:41 PM
^^ Either that or it's off a tooth.
Old 09-09-2009, 10:29 PM
Manybrews's Avatar
whomever installed it is an idiot.
Old 09-10-2009, 02:42 AM
les1's Avatar
Default Thanks to all comments..............
Thank you one & all. You are spot on with diagnosis. Took the car back & advised them of what maybe the problem which as you can imagine does not go down well. However problem corrected the car is fine now. Had me very concerned for a few days. Thanks again for your imput.......
marx88
06-30-2011 03:54 PM
raycam2kx
02-21-2008 11:08 PM
raycam2kx
14
10-06-2007 08:31 PM
raycam2kx
08-16-2007 08:33 PM
dsfii
05-10-2005 03:08 PM
Quick Reply: Galant 4 cyl timing belt changed..........
