Knob for heater on dash 2002 galant...
RE: **** for heater on dash 2002 galant...
Pull off the bezel around the radio/HVAC/cubby hole, then pull out the radio. You should now be able to see behind the HVAC panel. The heater dials are connected to cables - check to see if the cables are binding/catching anywhere.
You more than likely have a bent control cable. If you look under the drivers dash while manipulating the temperature control ****, you may be able to see where the hang up is. Good Luck!
Joel, CA
Joel, CA
Harv
02-24-2013 09:36 AM
mldave
12-15-2008 10:25 PM
p4c0
02-22-2007 07:36 PM
