Knob for heater on dash 2002 galant...
Old Jan 20, 2006 | 06:47 PM
sachmosis's Avatar
Default **** for heater on dash 2002 galant...
I think the **** for the temperature control is broken. How do I get it off to find out? I turn it and it jumps back by itself.
Old Jan 20, 2006 | 08:06 PM
DryBear's Avatar
Default RE: **** for heater on dash 2002 galant...
Pull off the bezel around the radio/HVAC/cubby hole, then pull out the radio. You should now be able to see behind the HVAC panel. The heater dials are connected to cables - check to see if the cables are binding/catching anywhere.
Old Jan 22, 2006 | 01:55 AM
Joel_CA's Avatar
You more than likely have a bent control cable. If you look under the drivers dash while manipulating the temperature control ****, you may be able to see where the hang up is. Good Luck!
Joel, CA
Harv
Feb 24, 2013 08:36 AM
mldave
Dec 15, 2008 09:25 PM
cahoca
Jul 8, 2008 12:09 AM
p4c0
Feb 22, 2007 06:36 PM
CO 3000GT
Aug 14, 2006 06:07 PM
