loss of power to radio and trip odometer
Old Dec 4, 2005 | 05:59 PM
BCS's Avatar
BCS
Default loss of power to radio and trip odometer
I just got a '00 Galant and am having trouble with the radio. Every time the car is turned off the radio goes into the security mode and needs the security code input to start it up again. I also noticed the the trip odometer resets each time the car is powered off so it seems like there is no power to the dash area with the car off. I also don't have the power locks working either so I don't know if this is part of the same problem. Any help would be appreciated.
Old May 21, 2012 | 10:14 AM
Sfh's Avatar
Sfh
Default same issues
I also suffer from the same issues. Checked all fuses, and cleaned battery cables/connections. Key in ignition chime also does not work, when driver door open and key is in but not turned on. Everything is "stock" as far as I know. Thank you in advance for any help or tips to solving this.
adwozere
May 23, 2015 06:11 AM
Sfh
May 27, 2012 09:19 AM
jdohe
Dec 12, 2010 07:00 AM
neurocrash
Apr 20, 2008 08:04 PM
BCS
Dec 7, 2005 04:26 PM
