strange idle problems
Old Jan 28, 2008 | 07:50 AM
shaun dk's Avatar
Default strange idle problems
Hi all
i`m an aussie bloke living in denmark and i have a couple of problems which may or maynot be related .
my car is a 91 galant 2,0 efi sohc .
1) when cold the car starts and runs at 1500 rpm then slowly drops down to 900rpm if not driven, this seems fine .However if i start the car cold and try to drive off then push the clutch in the revs drop right down to around 500. then a couple of seconds later increase again to 1500 rpm .this is a pain in the ar## as there are 6 stoplights between home and the kids school.
the guy at the wreakers wants 100 notes for a throttle body with tps, ics and mps still attatached .I pulled the ics (stepper motor) out today the worm gear spins ok when the key is turned to on so i don`t think its that . any ideas ?
2) with motor warm the use of accessories cause the car to idle down from 900rpm to about 700 rpm ,what causes this ? ive just replaced the alternator but thishas not helped .
could these problems be related what do you think .
thanks a bunch Shaun
Old Jan 28, 2008 | 09:13 AM
RMUDBUGS's Avatar
Default RE: strange idle problems
Anytime you disconect the battery it resets the computer and it no longer adjust for the carbon biuld up on the Throttle Body. Start by cleaning the Throttle Body.
Old Jan 28, 2008 | 11:14 PM
shaun dk's Avatar
tb is clean and i have reset ecu but no joy
shaun
Old Jan 29, 2008 | 01:04 PM
RMUDBUGS's Avatar
Probably the Idle Speed Control Motor then.
Old Feb 21, 2008 | 11:48 PM
mxmikie's Avatar
put a new o-ring on the biss adjustment screw
Old Feb 22, 2008 | 02:54 PM
ehsanabria's Avatar
what is the biss adjustment screw
Old Feb 23, 2008 | 11:33 PM
mxmikie's Avatar
biss is the air intake adjustment screw in the top left of the throttle body
justin210485
Mar 6, 2015 10:11 AM
servizluxor
Jan 25, 2012 02:53 PM
c577
Apr 26, 2009 03:37 PM
rosso75
Sep 20, 2008 07:46 AM
Ziggy
May 29, 2007 01:24 PM
