strange idle problems
Hi all
i`m an aussie bloke living in denmark and i have a couple of problems which may or maynot be related .
my car is a 91 galant 2,0 efi sohc .
1) when cold the car starts and runs at 1500 rpm then slowly drops down to 900rpm if not driven, this seems fine .However if i start the car cold and try to drive off then push the clutch in the revs drop right down to around 500. then a couple of seconds later increase again to 1500 rpm .this is a pain in the ar## as there are 6 stoplights between home and the kids school.
the guy at the wreakers wants 100 notes for a throttle body with tps, ics and mps still attatached .I pulled the ics (stepper motor) out today the worm gear spins ok when the key is turned to on so i don`t think its that . any ideas ?
2) with motor warm the use of accessories cause the car to idle down from 900rpm to about 700 rpm ,what causes this ? ive just replaced the alternator but thishas not helped .
could these problems be related what do you think .
thanks a bunch Shaun
justin210485
Mar 6, 2015 10:11 AM
servizluxor
Jan 25, 2012 02:53 PM
