Trans malfunction in OD
Old Jan 27, 2009 | 09:00 PM
BigB10774's Avatar
Default Trans malfunction in OD
I hope you guys can help me. I have a 1995 Mitsu Galant with auto trans w/OD. It started slipping in and out of gear when the OD switch is on. Really undrivable. With the switch in the off position it's fine. I'm getting suggestions such as shift solenoid, torque converter solenoid, etc. One guy on another board suggested the torque converter. The car is actually my son's. I have pretty good "shade tree" ability, but diagnosing a transmission is way outside my scope of expertise. Any suggestions would be greatly appreciated. Thanks
Old Jan 28, 2009 | 05:58 PM
Manybrews's Avatar
Default RE: Trans malfunction in OD
ruptured end clutch.
It can be replaced easily without transaxle removal, in under an hour.
you can buy the whole clutch assembly (which is definatly the way to go... dont "rebuild" the end clutch!) at your local mitsu dealer. Probably be 200-300 bucks.
check this link for some knowledge.
http://www.mirage-performance.com/Ec...endclutch.html
its very common.
Old Jan 28, 2009 | 06:47 PM
BigB10774's Avatar
Thanks manybrews. If I understand correctly I can purchase the whole clutch pack and just swap them out. The link you included describes teardown and rebuild. If I can buy it complete and pull one out and put the other one in as a complete assembly that's awesome. I don't know if I wan't to attempt a rebuild of the component. Thanks
Old Jan 29, 2009 | 06:21 PM
Manybrews's Avatar
google "Mitsubishi end clutch".
you'll probably find a lot of articles.
Old Jan 30, 2009 | 05:14 PM
ScotchNScotch's Avatar
I was glad to come across this post as I believe that I have a car experiencing the same problem. A 1998 Galant. In OD, it won't go anywhere, just revs the engine. Out of OD, the car moves, seems to get to pretty high rev (3500), then trys to shift, but seems to fail, then a few seconds later, shifts very hard (I'm assuming that this is some sort of "Limp mode"). Doesn't seem to shift again after that, but I've only run it up to about 40mph since it started this problem. Also, no reverse at all. When I checked the transmission fluid last week (prior to this problem showing up), it was good, now it is hard to get a reading as the fluid seems to be overheated and bubbles up the stick too much. But I'm again assuming that it is alright, just burnt.
Obviously, I would like to hope that replacing the end clutch would be my total solution, but m afraid that maybe the transmission is too far gone. I wan't able to find any listing for the complete replacement end clutch online, so I'm thinking that the dealer is the only place to get this animal?
Thanks,
Old Feb 2, 2009 | 08:48 PM
BigB10774's Avatar
Sounds pretty much like what I'm dealing with. If you find the complete assembly let me know. Good luck
Old Feb 4, 2009 | 07:46 PM
I'm going to check with the dealer tomorrow. Hopefully it's an easy part to come by.
Old Feb 7, 2009 | 11:57 AM
BigB10774's Avatar
Great. I'd be real interested in knowing if you located the part and what it cost. Thanks for the update. Bill
foolane
May 14, 2013 06:16 PM
gant
Apr 3, 2007 11:29 PM
Dookitchen
Oct 9, 2006 12:54 AM
MissFox98Spyder
May 26, 2006 03:58 PM
boosty
Sep 17, 2004 06:17 PM
