2002 Lancer will not start?????
Old Apr 24, 2007 | 12:21 AM
stinkymcgee's Avatar
Default 2002 Lancer will not start?????
I have a 2002 Lancer that died while I was driving and now it will not start. It is throwing a p0340 trouble code for camshaft pos sensor circuit malf. I have changed the sensor, spark plugs, s.p. wires, & coils. tha fuel pump is coming on and I am getting fuel up to the fuel rail. To me it seems that the timing belt may have jumped a couple of teeth. I hope not this being an interference motor. I took the timing belt cover off to make sure it was not broken. ANY HELP WOULD BE APPRECIATED!!!!!!!
Old Apr 24, 2007 | 06:40 PM
Dusty Eclipse's Avatar
Default RE: 2002 Lancer will not start?????
Sounds like you need to adjust the timing. There should be a writeup on that somewhere on here...
Old Apr 24, 2007 | 06:41 PM
Check if you are getting spark. You can do that by removing ONE of the spark plugs and attaching it to the spark plug wire.. and have someone crank it over while you watch for a spark. Alternativly you can just grab onto it while someone trys to turn it over... its a shocking experiance .
My next thought would be the ECU.
Old Apr 24, 2007 | 06:43 PM
Thats probably a better answer. More amusing too.
Old Apr 24, 2007 | 06:49 PM
VR4GARY's Avatar
If you have the timing belt cover off, check the timing marks on the cam and crank gears to make sure they match up.
Old Apr 24, 2007 | 06:50 PM
I just think we should start with the cheaper possibilities... dont you agree?
Old Apr 28, 2007 | 02:28 AM
blackdiamond's Avatar
if it helps, its a non-interference motor, so its not toast. mine died at idle and i cleaned the throttle body, and 20k later, its never died again.
MathewGarrett
20
May 15, 2013 09:02 PM
myko
Mar 21, 2011 11:15 PM
raff1ut
Mar 20, 2007 11:18 AM
raff1ut
Feb 21, 2007 02:54 PM
ruslancer
Mar 5, 2005 02:59 PM
