Idle Problem
Old Apr 25, 2011 | 08:54 PM
ylkien's Avatar
Default Idle Problem
Hi all,
I am having a problem. When the engine is slowly revved up to 1.6k rpm, the rpm will automatically go back down to 1.0k rpm. Problem does not exist when engine is quickly revved or when aircon is turned on.
When that occurs, the TPS sensor output seems to be stuck at 0.6V (the voltage should come down to ~0.5V when idling at 1.0k rpm).
I have cleaned the TB and checked the hoses. No problem with the ISC or TPS as i have changed it several times and it is still the same symptom.
Any ideas what is going on ?
Old May 6, 2011 | 06:43 AM
mxmikie's Avatar
did you replace the o-ring on the biss screw ????
yamahablaster8230
Aug 29, 2006 09:28 AM
RCJr9186
Jan 2, 2006 06:32 PM
rbland
Oct 7, 2004 04:16 AM
VR4Restored
Aug 14, 2004 01:09 AM
1rippinGT
Mar 24, 2004 01:38 PM
