95 mirage timing 1.5l
Old Oct 18, 2008 | 09:31 PM
javelinpr's Avatar
Default 95 mirage timing 1.5l
Im working on my friends 95 mirage 1.5l. it bent a rod and destroyed a piston when he was trying to use the car as a jet ski. well i have some doubts on how to set the timing right. since the motor was stuck i couldnt move the timing mark into place and i had to tear it apart as it was.
i have a manual i downloaded online, what i need to know is:
whats the piston diagram? which one is #1 and the others?
the crankshaft gear is the smaller and this motor moves two pistons up and two down simultaneously. can i align the crank timing gear in the mark and thats it? if the ratio is 2:1 should i worry about getting the right turn or setting either of the turns is the same thing?? as long as i set the head right??
thanks for the info!!!
Old Nov 6, 2008 | 01:09 PM
BEAT's Avatar
Default RE: 95 mirage timing 1.5l
We cant help you sorry you broke the piston and rod.
Engine rebuilt is the best way.
Old Dec 4, 2008 | 03:13 PM
Stylis's Avatar
Here you go http://www.gen-parts.com/pdf2/0C1947.pdf
marshmallow746
Jun 10, 2022 10:20 PM
judien
Mar 9, 2018 03:41 PM
sherk
Mar 5, 2013 10:47 AM
8000RPMS
Aug 30, 2007 05:49 AM
bigguy6f4
1st Generation
Jul 9, 2007 05:45 PM
