I'm stumped are you smarter then me
Old Apr 10, 2018 | 03:39 AM
Bigchief's Avatar
Default I'm stumped replaced everything just about
Well I have a 1997 mirage 5 speed 1.5 btw I went 7 pages in the forums and used the search
it start runs weak I can get up to highway speeds but it takes forever I get no power at wot in any gear.
I had bad plugs about 1500 miles ago so I replaced them gapped out to .42.
checked plugs looked good
replaced cap and rotor on the distubuter no change
checked spark plug wires and injectors while it ran by removing each one all fine
checked vacuum lines for leaks didn't find any replaced a few lines no fix DID NOTICE WHEN I TOOK OFF THE VACUUM LINE ON THE FUEL RAIL AND INTAKE MANIFOLD I WAS ABLE TO TEST DRIVE AND IT HAD FULL POWER FOR ONE PULL COULD NOT replicate
changed fuel filter no change
checked cat after driving home today wasn't red hot or anything
I have a vacuum tester but honestly don't know how to use it and I'm also not getting a cel
thanks for reading any advice would be appreciated
Old Apr 10, 2018 | 01:22 PM
Bigchief's Avatar
So I just went for a test drive and decided to unplug the tps sensor and noticed no difference so I think I found the culprit also the gas mileage has been complete ****
Old Apr 12, 2018 | 01:46 AM
Bigchief's Avatar
I've now changed the plugs and wires again cut the cat off but before this the car is a complete turd and won't get up to any sort of speed and when starting it after it started I could hold my foot to the floor for 30 secs before it started to even rev up
Old Apr 13, 2018 | 11:05 AM
Bigchief's Avatar
I've changed the distributor now and won't move under load and still can't rev it
Erictaylor
Mar 12, 2017 01:43 AM
master_disaster
Mar 19, 2008 09:44 PM
rexbd
Jan 29, 2008 07:18 PM
RCJr9186
Jan 20, 2007 07:49 PM
