TP switch
Old Nov 3, 2009 | 10:29 PM
zx12ryder's Avatar
Default TP switch
Replaced a throttle position switch on my dads gf car. After installing and checking the voltages (reference voltage, idle and WOT) that were within ranges as specified in the service manual... the car had a really low idle once it warmed up. It would die out when i drove it down the driveway and came to a stop. Also once the replacement TP switch was intalled the "check engine" light that was illuminated went out. However after sitting for a while and turning the vehicle back on the "check engine" reilluminated. The reason for the TP switch change was due to get a code from the OBDII scanner that referenced the TP switch. 0120
Could there be any other problems to cause a code like that?
Old Nov 7, 2009 | 05:20 PM
Manybrews's Avatar
might help if you tell us what you're driving.
Old Nov 8, 2009 | 02:51 AM
jason clipse's Avatar
this post is in the mirage forum so thats what i would assume it to be. and zx12 did u try to clean the maf with maf cleaner? if that doesnt work, maybe a bad maf sometimes they can be tested at autozone
Old Nov 9, 2009 | 08:33 AM
zx12ryder's Avatar
sorry fellas....its a 97 mirage. also the latest news is now it is showing a 0170 code which is the "fuel trim-bank 1". so this is now the priority code. the 0120 code stop showing after the TP switch was replaced. ....also no i havent tried to clean the maf.....will try that.
Old Nov 9, 2009 | 08:43 AM
the fuel trim bank one issue could be caused by the maf. this is a 4 cycl right so there is only one bank, which means you are either running rich or lean. could be caused by o2 sensor or maf, usually its the o2 sensor. but usually that wont make the car idle wierd or shut off on decel, that sounds more like the maf, like i said i would take it to an autozone and see if they can test it.
Old Nov 10, 2009 | 07:23 AM
zx12ryder's Avatar
yes it is a 4 cylinder ...very good info....will get the maf tested,....i think the owner already has a new o2 sensor but never had it installed. Thanks...glad i joined this site.
Old Nov 10, 2009 | 10:20 AM
try cleaning it first, that may be it. or actually when was the last time the air filter was replaced, it could be as simple as that. the air filter is so clogged that it isnt getting any air. then if cleaning it doesnt work and the air filter is good then try getting it tested
Dumbo45
Jan 23, 2009 09:29 AM
Pajoz
Mar 18, 2005 11:06 AM
sparkyden
Feb 5, 2005 04:54 PM
Davet2
Oct 15, 2004 03:15 PM
osagemike
Sep 24, 2004 04:36 PM
