02 Montero brake pedal sticks...
Old Feb 26, 2010 | 08:16 PM
reaper1278's Avatar
Default 02 Montero brake pedal sticks...
So, I bought the Montero Limited used. Ever since I bought the vehicle, the brake pedal sticks a bit after braking. The pedal will remain down for about 2 seconds before releasing and allowing the vehicle to move. Any ideas what to look for for a cause? I am a Chevy man, but I understand the components, if you could explain what to look for. Thanks
Old Apr 26, 2010 | 03:58 PM
cougar8000's Avatar
I have the same issue with my wifes Montero. First off, brakes do work fine. It is just after seating at the light, they wont release sometimes. I just make another pump and off they go.
I have a suspicion that it is due to dirt and old brake fluid. I will be changing pads in a week or two and will do a full brake fluid swap. Will see what happens.
Looking at the date of your post, You most likely have found a solution already care to share it.
Old Apr 27, 2010 | 11:44 AM
reaper1278's Avatar
No, I have not found a solution as of yet. If changing the fluids helps, please let me know.
cllamont
4th Generation
11
Oct 6, 2014 02:21 PM
thomascgty
Jul 16, 2013 06:36 PM
Pedro....
Feb 13, 2013 04:02 PM
brianwis
Sep 22, 2009 09:09 AM
acapulco36
Feb 23, 2007 04:08 AM
