02 transmission problems
Old 02-08-2007, 08:39 PM
Manybrews's Avatar
Default RE: 02 transmission problems
once again, you should not use anything but mitsu fluid.
do NOT use "additives" installed in different fluids.
do NOT use different fluids.
I cant say it anymore ways than Ive already said it. Stop questioning it, and use mitsu fluid only.
Old 02-08-2007, 09:12 PM
tj90's Avatar
After being on this board and the other one, seems like Transmissions are the #1 issue with the monteros. A majority of the time, problems arise cause somebody stuffed non-approved fluid in the AT. Knowing what I know now, and knowing that Im probably paying too much for the SP-III, Ill use it. Its just too risky to save seriously - $50 - every $30k miles, running another ATF fluid. The truck is just too darn expensive.
With that said, I use non-mitsu lubes (BUT SAME GRADE) in other parts of the drive line. Mobil 1 in the motor, Speciality formulations in the diffs and transfer case - but I make sure they are 5w-30, GL5 and GL4 SAE grades respectively.
Other than blinking 4x4 lights and trannys getting trashed from wrong fluid - these trucks are solid!!!
Old 02-08-2007, 09:47 PM
ORIGINAL: tj90
IMHO the tranny's getting trashed from wrong fluid is a stupid owner error, and not a Montero "issue".
Old 10-01-2012, 08:03 PM
7-UP BILL's Avatar
I use Castrol Import Trans fluid. It is Diamond III acceptable. Been using for 60 K miles now. Changed twice. Trans never shifted better.
jp2000
01-01-2012 05:21 PM
94 Mitsu Eclipse
12-20-2010 06:59 PM
kandy eclipse
12-16-2005 06:58 PM
bfunk
08-01-2005 05:21 PM
99eclipse
12-02-2004 04:11 AM
Quick Reply: 02 transmission problems
