02 transmission problems
Old Feb 8, 2007 | 08:39 PM
Manybrews's Avatar
Default RE: 02 transmission problems
once again, you should not use anything but mitsu fluid.
do NOT use "additives" installed in different fluids.
do NOT use different fluids.
I cant say it anymore ways than Ive already said it. Stop questioning it, and use mitsu fluid only.
Old Feb 8, 2007 | 09:12 PM
tj90's Avatar
After being on this board and the other one, seems like Transmissions are the #1 issue with the monteros. A majority of the time, problems arise cause somebody stuffed non-approved fluid in the AT. Knowing what I know now, and knowing that Im probably paying too much for the SP-III, Ill use it. Its just too risky to save seriously - $50 - every $30k miles, running another ATF fluid. The truck is just too darn expensive.
With that said, I use non-mitsu lubes (BUT SAME GRADE) in other parts of the drive line. Mobil 1 in the motor, Speciality formulations in the diffs and transfer case - but I make sure they are 5w-30, GL5 and GL4 SAE grades respectively.
Other than blinking 4x4 lights and trannys getting trashed from wrong fluid - these trucks are solid!!!
Old Feb 8, 2007 | 09:47 PM
off roader's Avatar
ORIGINAL: tj90
IMHO the tranny's getting trashed from wrong fluid is a stupid owner error, and not a Montero "issue".
Old Oct 1, 2012 | 08:03 PM
7-UP BILL's Avatar
I use Castrol Import Trans fluid. It is Diamond III acceptable. Been using for 60 K miles now. Changed twice. Trans never shifted better.
jp2000
Jan 1, 2012 05:21 PM
94 Mitsu Eclipse
Dec 20, 2010 06:59 PM
kandy eclipse
Dec 16, 2005 06:58 PM
bfunk
Aug 1, 2005 05:21 PM
99eclipse
Dec 2, 2004 04:11 AM
