03 no start
Old Aug 23, 2015 | 06:22 PM
  #41
Guyfromhe's Avatar
Maybe make a quick video? Might help more than a text description...
Old Aug 23, 2015 | 07:39 PM
  #42
jp1985's Avatar
Originally Posted by HunterD
That is a tough one to diagnose remotely. It is possible that you have a bad motor mount and as you went around the corner the motor moved/shifted producing the metal clunk you heard. In this case it is also possible that it pulled on some part of wire harness and momentarily disconnected a or shorted a wire killing the engine in the process. This is purely speculative - I'm just throwing an idea out there.
I do not know what you mean by spark plug noise - is it electrical spark type of a noise? Perhaps you have a bad spark plug wire that is shorting out. You can start you truck in the dark and look in the engine compartment to see if you notice any wires sparking to ground.
The loud clicking noise might be valve lifter slap. It usually happens on older engines when they sit without running for long time (oil drains out of the lifters). It should go away one engine warms up. There is also a procedure for bleeding trapped air out of the lifters. It has been described many times on this forum.
Yes i totally understand how it is hard to remotely diagnose it without even hearing/seeing it.
i was just asking for ideas of what it could be. I need to just get time to completely open it up and fix any issues while am in there. Its going to need the manifold gaskets replaced as they are leaking so it would be a good time to do a full tune up as well as look for any other issues. There are a bunch of wires and connectors that are not connected in the engine bay. if i post a picture would you guys be able to give me some info on what you think it goes to?
and thank you again for your help guys.
Old Aug 23, 2015 | 08:04 PM
  #43
Guyfromhe's Avatar
You know what they say.. A picture is worth 1000 words...
I wouldn't expect to see a bunch of random disconnected wires flapping around in the breeze in there.. Can you see where they should be connected to?
It's possible some may be for features you don't have or a different engine or something but it should be obviously tied down and neat.
Old Aug 23, 2015 | 08:10 PM
  #44
jp1985's Avatar
It looks like a pig tail connector and it is really close to the MAF connector. It looks like somone did some wiring to it because its electrical taped up all crappy like. I am looking for the picture i know i took it i just cant find it stupid iphones.
Old Aug 23, 2015 | 08:17 PM
  #45
That would kill your engine (a bad MAF connector).
Old Aug 24, 2015 | 12:39 AM
  #46
jp1985's Avatar
It has the MAF connector hooked in, but its a smaller wires with a attachment on the end. I have looked all over for what it could go to but i cannot find it.
When you said kill your engine do you mean kill as in ruin or kill as in shut off?
I am still looking for that picture to show you guys.
Old Aug 24, 2015 | 01:45 PM
  #47
I meant to shut it off under conditions you described. Can you post a photo of those wires.
Old Aug 24, 2015 | 01:48 PM
  #48
jp1985's Avatar
Its at my fathers house where it broke down. I am heading that way today so i will re take the pictures today as i cant find the old ones i think the phone deleted them.
will post them asap.
Old Aug 24, 2015 | 07:09 PM
  #49
jp1985's Avatar
Here are the pics.
I thought it was odd to have a wire going through the serpintine belt has anyone ever had a wire like that??
Attached Thumbnails 03 no start-img_0588.jpg   03 no start-img_0589.jpg   03 no start-img_0592.jpg   03 no start-img_0598.jpg   03 no start-img_0600.jpg
Old Aug 24, 2015 | 09:14 PM
  #50
Guyfromhe's Avatar
That looks like an important wire and it also looks like someone was messing with it after the factory... Do you have the other end for that wire?
