2001 Montero 3.5L Overheating?
Old Feb 20, 2015 | 12:19 PM
guangui's Avatar
Default 2001 Montero 3.5L Overheating?
A friend of mine has an '01 Monty 3.5L, when driving it the SUV will mark in the temp gauge like if it is overheating or overheated, but in reality there is no signs of it overheating, also the needle goes slightly up and down randomly. It is always over 3/4 of the way and reaches the top (overheated) sometimes, then comes back down a little. I checked it, and the engine does not show any signs of overheating(no steam coming out, no knocking and pinging, you can touch the radiator cap for a couple of seconds, etc.). Engine Light just came up, and I haven't scanned, but my gut feeling is the temperature sensor at the engine must be faulty. What do you guys think?
Old Feb 20, 2015 | 05:47 PM
TheMole's Avatar
The temp gauges are known to become faulty on these models. A lot of info here on the forum.
Old Feb 23, 2015 | 10:20 AM
mlduncan96's Avatar
https://mitsubishiforum.com/forum/mi...p-gauge-47609/
Third post; the second link repair is the one I followed. It is the least expensive and does the trick. Needed for repair: time, a soldering iron with small tip and maybe a little solder.
Old Feb 24, 2015 | 04:56 AM
2001Mitch3.5XS's Avatar
What Exactly did you do to fix your problem !!!!
Old Feb 26, 2015 | 07:49 AM
mlduncan96's Avatar
I applied a little new solder to a resistor on the control board of the instrument cluster. It was very simple.
Here is the link to the article I followed.
How to fix the faulty temp gauge on a Pajero/Shogun/Montero NM (2001-1003) | Pajero.guru
oldslowguy
Jul 13, 2014 05:05 AM
Mivecmagic
13
Sep 1, 2013 07:04 AM
cthj
Aug 24, 2012 06:40 AM
relisiii
Mar 27, 2012 11:52 PM
tomek
Nov 1, 2006 04:32 PM
